holley carb
Old Jan 1, 2008 | 11:21 PM
rusty7983's Avatar
rusty7983
holley carb
what do you use to remove gaskets and float bowls? i don't want to pry and score them. i have a couple of metering bodies i need to get off. i had this happen before but its been along time, and i don't remember the solution.
Old Jan 1, 2008 | 11:22 PM
ford390gashog's Avatar
ford390gashog
I use plastic putty knives. You can get them at any hardware store. You will ruin the plastic scraper before you harm the soft aluminum bowls.
Old Jan 1, 2008 | 11:34 PM
LxMan1's Avatar
LxMan1
Gasket remover softens the gaskets. I usually just pry them on top with a screw driver away from the gasket surface and under the choke horn to remove them from the main body.
