SeaFoam?
Old Jan 10, 2008 | 06:30 PM
bazzman1953's Avatar
bazzman1953
http://www.seafoamsales.com/
Never tried it myself, but this isn't the first forum that I've come across it being mentioned, so I can't comment on whether it's snake-oil or not. I've toyed with the idea, but at 177,xx mi. I am leary.
Old Jan 10, 2008 | 08:09 PM
bazzman1953
Or check out this myspace thread, only the first page is pertainent,
http://forums.myspace.com/t/3659213....ums.viewthread
Again, I just don't know. Snake oil or not?
PTFE is snake oil. Is this?
Old Jan 10, 2008 | 08:27 PM
drb1956's Avatar
drb1956
Hey, you guys ever try Marvel Mystery oil?? Great stuff!! I've used it a couple of times-seems to pick up the pace when I use it in the gas. In the winter when its cold, I sub a 1/2 quart of oil with this--starts great when it sub-zero out, and doesn't beat up the viscosity of your oil. Good stuff!!! It's been around a long time...
Old Jan 10, 2008 | 08:34 PM
jv42287's Avatar
jv42287
well like i said earlier, i used this stuff for the first time as described. I didnt feel or see much difference at first. However, i just took it for a drive, it is a second vehicle, after sitting for four days and the idle is smoother and it idles where it should now. I was idling around 1000-1200 after doing everything i could. Now it is around 800, i know its a little high still but it sure helped a lot. I would definately recommend it!!!
Old Jan 10, 2008 | 09:20 PM
bazzman1953
jv4, glad to hear it seems to have worked, maybe come spring I'll try it.
drb, better to go with a good 5w20 imho.
My '94 doesn't call for a weight that low [it's 10w30] but my own internet research leans toward the lower numbers [I would use 0w20 synth but the trucks burns oil], so I use 5w20 dino.
Old Jan 10, 2008 | 09:28 PM
drb1956's Avatar
drb1956
I use Super Tech (Wal-Mart) 5w30. Had a little chatter on start up on those frigid morns,--changed oil, added Marvel, no chatter, easy starts. Had a Dodge van for awhile, 6 qt.oil pan--in the winter, I would sub 1 qt. for easy start up on those freezing days.
Old Jan 10, 2008 | 09:47 PM
grass happens's Avatar
grass happens
Instead of the needle technique, buy a can of Deep Creep. its sea foam in aerosol form. I use it to treat the fuel of my lawn stuff. I've never tried it in my ranger, it magically loses 1 qt of 5wo every oil change as it...
Old Jan 10, 2008 | 10:17 PM
jimdandy's Avatar
jimdandy
Originally Posted by Bruceknee
ok I have to ask....what the heck is seafoam?? i never heard of this stuff, is it really worth while cause i'd like to try it out on my "99"
It's napthene mixed with pale oil. It works miracles. jd
Old Jan 10, 2008 | 10:49 PM
BuffmanLT1's Avatar
BuffmanLT1
While there are other fuel system cleaners out there that far outperform Seafoam (such as Chevron with Techron's Fuel System Cleaner), seafoam works fairly well when sucking it into the intake via a vacuum line. Works similiar to misting water into a carbed engine to break up carbon.
Matt
Old Jan 11, 2008 | 09:06 AM
smokn03's Avatar
smokn03
old school guy's tell me.that atf fluid does miracles also.atf is really a good cleaning agent for motors.you use it like seafoam.except pour it in the carb or throttle body slow and only about half a quart.i tried it on a old s-10 i had and it was cool.if you think seafoam makes smoke you have no idea.
Old Jan 11, 2008 | 01:15 PM
customstringer's Avatar
customstringer
http://www.seafoamsales.com/motorTuneUp.htm
Old Jan 11, 2008 | 03:26 PM
wendell borror's Avatar
wendell borror
It's recomended that you use seafoam on the 3.0 once it gets some miles on it. The 3.0 is bad to carbon up, seafoam will help keep it clean.
timbuctooCal
Mar 1, 2016 11:27 PM
stonerboys
16
Dec 29, 2012 02:15 PM
andrew1989
16
Sep 22, 2012 03:06 PM
justin25taylor
Sep 8, 2007 07:59 AM
willie4406
21
Nov 23, 2006 11:45 PM
