Trying to match '07 lariat wood trim...
I'm not real sure as far as what kind of wood/stain to use, but you may want to look into www.oemdash.com . The guy there is supposed to be able to match the factory wood grain real well (and the pictures of the excursion parts seem to match).
Not sure about the 07's but, my 05 lariat has cherry wood. I made a shift **** out of cherry and stained it to match. So if you can get a hold of some cherry check the grain with your truck. There are also some lumber yards that have cherry veneer with double stick tape on the back. Just peel and stick.
The actual name of the trim in the 06 Lariat per Superior Dash is Cherry Zebrano. Don't know if that's what Ford calls it or if 06 and 07 is the same. I'm the So, Tx Distributor for these people and while I don't do a great many dash kits, the ones I have done using Superior have always been a perfect match. From looking at the newer Lariat's, the interior seems to be the same as mine (06). Don't know if what you're doing would be covered by a dash/console kit or you're just trying to match color on actual wood. Good luck and send us pictures of the finished product.
Jeffrey Altice
07-21-2013 07:32 PM
