need help
Old Jan 1, 2008 | 01:49 PM
hanklin's Avatar
hanklin
need help
My ses lite came on and I pulled the codes indicating my vss, I reset the dtc`s and it (ses) has not come back on.My O/D lite was flashing as well before I reset.Everything is ok now ( going on about 15 miles) How long do I have until armaggedon? I still have to go about 220 miles before I can fix it,whaddya think.Help appreciated
Hanklin
Old Jan 1, 2008 | 01:58 PM
conkster's Avatar
conkster
its most likely the vss sensor on the rear pumpkin also known as the rear abs sensor. it costs about $11 at napa. real easy to change. shouldn't be a problem to drive till you can pick up the part.
Edit: Napa part # 530780
Old Jan 1, 2008 | 01:59 PM
rbaker6336's Avatar
rbaker6336
it may come back in a few miles or a few thousand,probly your VSS is bad
Old Jan 1, 2008 | 02:01 PM
hanklin's Avatar
hanklin
do I follow a line to where?What do I look for? Thanks
Hanklin
Old Jan 1, 2008 | 02:09 PM
rbaker6336's Avatar
rbaker6336
it's on rear axle housing
Old Jan 1, 2008 | 02:12 PM
spinge's Avatar
spinge
It is a sensor on the rear pumpkin - mounts alot like the CPS
Old Jan 1, 2008 | 02:13 PM
dieselboy3278's Avatar
dieselboy3278
Hanklin
if the o/d light is flashing i would get the trany fluid changed as soon as you can mine was flashing changed the fluid and it was pretty nasty looking
Old Jan 1, 2008 | 02:45 PM
hanklin's Avatar
hanklin
Thanks much,I`ll get on it asap
Hanklin
Old Jan 7, 2008 | 10:25 PM
hanklin's Avatar
hanklin
Pulled it out and changed with a new one, I`m curiuos about the shavings mixed in the grease, how much is "normal" I do have 245,000 on the odometer
Hanklin
Old Jan 7, 2008 | 11:44 PM
Fat Diesel's Avatar
Fat Diesel
At 245k, I'd say it's good to go. Maybe treat it to some new juice. I do about every 50k.
Old Jan 8, 2008 | 02:44 AM
AustinS's Avatar
AustinS
with 245K you'll have a fair amount of shavings. But don't be too alarmed. I agree with those who recommended a fluid change. If you have a limited slip rear end, don't forget the friction modifier additive.
If you are concerned with wear, after you change the fluid just check it every 12k or so miles. Personally, I would swap the fluid and forget about it. There are too many other things in life that cause stress. No sense in adding more
Austin
Old Jan 8, 2008 | 07:41 AM
hanklin's Avatar
hanklin
Austin
I hear ya on that,I`ll change in a few days thanks to all advice
Hanklin
Old Jan 10, 2008 | 07:39 PM
hanklin's Avatar
hanklin
Bad news , ireplaced the vss 3 days ago , now
my o/d lite is flashing again,twice in 2 days. Any ideas what is going on?
Hanklin
Old Jan 10, 2008 | 08:33 PM
spinge's Avatar
spinge
At this point I would try to get the codes read - sorry. Is the light blinking in a pattern? It might be trying to give you a code.
Old Jan 10, 2008 | 08:38 PM
hanklin's Avatar
hanklin
I pilled the codes and they came as vss, so I`m at a loss. the blinking is consistent , you know like a drip from a faucet. I reset my dtc`s and all is fine and then it ciomes on.Thinking about it the blinking (probs) happen when I`m backing up, like in my driveway,,,,, thoughts?
Hanklin
