Still running too lean, need help
Old Jan 1, 2008 | 11:38 AM
joe.mcfadden's Avatar
joe.mcfadden
HELLO ALL
And happy New Year! I have replaced fuel pumps, oxygen sensors, one fuel filter, EGR valve, and the EGR valve sensor. I’m 99% sure there are no vacuum leaks. However, I still get DTC TOO LEAN at both sensors. Next I guess I will replace the fuel pressure regulator. Any other suggestions out there would be greatly appreciated thanks.
Old Jan 1, 2008 | 02:30 PM
Skandocious's Avatar
Skandocious
How are your cats? You sure they're not plugged?
You might want to try TESTING some of these parts before spending all this money to replace them. A Haynes or Chiltons manual should give you all the electrical specs for testing your sensors with a multimeter and making sure they check out.
Old Jan 1, 2008 | 06:09 PM
Snowseeker's Avatar
Snowseeker
Whats your fuel pressure at?
Old Jan 1, 2008 | 06:21 PM
italianstallion's Avatar
italianstallion
If fuel pressure checks okay, they check manifold vac. reading could be intake leak.
