heater core swap....
Old Jan 1, 2008 | 09:17 AM
hogdogs's Avatar
hogdogs
What all is involved? What tools will I need? I rolled over my wife's jeep cherokee some months back and lost several tools out of my 2 duffle bags when stuff went flying. We only have one ride so once I tear into this I am going to be stuck here.
Thanks in advance,
Brent
Old Jan 1, 2008 | 09:35 AM
86caprirs's Avatar
86caprirs
It is a simple procedure that should only take an hour or so.Remove glove box door.You will look through the area that the glove box was and see and access door held on by 10 or so screws.Remove screws and pull off door.Next remove hoses from heater core and remove heater core from inside cab.Reverse for install.Bleed cooling system and heater core.Done.
Old Jan 1, 2008 | 09:41 AM
hogdogs's Avatar
hogdogs
WOW good to hear... BTW it is a 90 with 300 in it...
Brent
Old Jan 1, 2008 | 09:54 AM
95F350XL's Avatar
95F350XL
Thats a super easy sounding heater core, Def alot easier then my friends moms 96 stang. It took like 2 days for the shop to do it.
Old Jan 1, 2008 | 11:13 AM
quicklook2's Avatar
quicklook2
mark which heater hose goes where before removing.
do not buy the cheapest core or you may have problems.
Old Jan 1, 2008 | 12:02 PM
jroehl's Avatar
jroehl
You may also have to loosen some of the screws holding up the right side of the dash--this will give you a little more wiggle room when taking out the core and getting the new one in.
Jason
Old Jan 1, 2008 | 12:07 PM
86caprirs's Avatar
86caprirs
The Mustang you have to pull the dash out. A lot more involved.But 2 days seems like a long time.It only pays 6 hours to do it.Should have been done in 4 hours or half a day.
Old Jan 1, 2008 | 12:52 PM
hogdogs's Avatar
hogdogs
Wife is on the way to advance to buy it... Where will I locate these dash screws? Are they phillips? i reckon they fail pretty easy since advance has 8 in stock...
Brent
Old Jan 1, 2008 | 01:40 PM
Old_Paint's Avatar
Old_Paint
Ok, my turn to sound like the village idiot (again, maybe). What difference does it make which direction the coolant flows through the heater core? I mean, if the flow is backward, does that turn it into an air-conditioner? (being sarcastic, sorry). Doesn't really matter. Pump hot coolant through it, blow air across it to warm the air, return the coolant to the main system. I don't think it will matter whether the coolant goes from left to right or up instead of down. There is no check valve in that core, otherwise, it would be pretty difficult to clean it out with a garden hose. I'd really like to see someone elses theory on why it matters which hose goes where, unless, of course, they're different diameter hoses. That would make a difference.
Old Jan 1, 2008 | 02:07 PM
Dean88's Avatar
Dean88
I don't know why it matters, alls I know is that it does. It thought like you and didn't mark my hoses when I replaced my heater core, and it sucked, swapped the hoses, and it was much better.
Old Jan 1, 2008 | 02:11 PM
netscaner's Avatar
netscaner
It definatelly makes a difference in efficiency.
You want the coldest air in the flow to go over the coolest part of the coils and the warmest air in the flow to go over the warmest part of the coils.
The same reason a downdraft furnace is more efficient than an updraft system.
Old Jan 1, 2008 | 02:33 PM
Old_Paint's Avatar
Old_Paint
Maybe I need to look a little closer at the construction of the heater core in this truck. Mine's never been out, so I have no idea what it looks like up close. But, if it's made like a mini radiator, I still question what difference it makes. This one I gotta see to believe. Guess I could just swap the hoses around on mine to see if it makes a difference. Someone got a pic of one they can post?
Old Jan 1, 2008 | 03:01 PM
hogdogs's Avatar
hogdogs
Well as a matter of fact... I will have a pic for you in an hour or 2... I have dial up so bare with me... I hate doing the p-bucket thing and might procrastinate a bit!
Brent
Old Jan 1, 2008 | 03:07 PM
quicklook2's Avatar
quicklook2
this has been discussed before with nothing decided.
mine are on the way the ford service manual says and the heater works fine.
Old Jan 1, 2008 | 04:18 PM
hogdogs's Avatar
hogdogs
little more help please...
Okay old one is out... I didn't loosen dash and chipped off one part of the lip on the box with an alingment pin... How many screws and where at too loosen the dash some to put in new one? This mexirican new core don't have brazed tubes! They are just crimped into nipples so I don't want to wrench them at all going in...
After lookin' at it I see no reason to worry about which hose goes where...
brent
