are you happy??
did you change anything on the front ?
i have a 60 up front
is your's 4 x 4 ?
i have 5.83 gears front and back...
well i have a 76 f100 4x4 dana 60front and 70rear with 5.13 gears airlockers and 19'' of lift and it was a real dog to stop with 44s (it had disc up front and drums on the rear) i put disc on the rear and hydro-boost on instead of the vac-booster and it stops better than most stock trucks do of that age.
ok
will have the same tires
same axles 390 power
4 link suspension on a very much shortened m715 army truck frame.
guess i know where to go from here.
thanks
