Intake Whistle?
Old Dec 31, 2007 | 09:47 PM
zamboni250's Avatar
zamboni250
Intake Whistle?
Recently, when starting my truck in the morning I get a whistling sound from the engine compartment. I assume that this is due to the very cold out side air temp. My truck is all stock for now so no aftermarket intake. Has anyone else experienced this? No big deal or a symptom of a big deal? Any info is always good. Thanks in advance.
Old Dec 31, 2007 | 10:41 PM
Ultramagdan's Avatar
Ultramagdan
Usually an intake whistle is the result of a fitting too loose. I would check to see that all components are snug (not tight since they are cold). Pop the hood next time and grab a-hold of the any suspect tubing and that should point you in the right direction.
Old Jan 1, 2008 | 10:56 AM
zamboni250's Avatar
zamboni250
Thanks for the reply. I tried that and could not find anything questionable. I will try again and see if I missed something.
Old Jan 1, 2008 | 10:58 AM
Mr Jimi's Avatar
Mr Jimi
Spray something on the intake and when the whistle goes away you have found it and remember that intakes are torqued to certain specs.
Jim
Old Jan 1, 2008 | 11:57 AM
irishammer's Avatar
irishammer
Zamboni it is probably your alternator....there is a TSB on it I believe. My 2004 does the same thing.
Old Jan 1, 2008 | 12:00 PM
zamboni250's Avatar
zamboni250
Thanks for the info. I will check on the TSB.
Old Jan 25, 2008 | 02:35 PM
born2huntwi's Avatar
born2huntwi
irishammer, I couldn't find the TSB on this site. Any idea where I can find it?
Old Jan 25, 2008 | 05:14 PM
ech0sh4y's Avatar
ech0sh4y
I'd like to know cause my 05 does the same think the first time i thought i had a cat caught in my drive belt =)
Old Jan 25, 2008 | 05:28 PM
irishammer's Avatar
irishammer
I don't see the TSB either...I know there were some posts on here awhile back about this...sorry for the misinformation. I do have the whistle though...
Old Jan 25, 2008 | 08:20 PM
chetlogan's Avatar
chetlogan
Whistler here too!
'08 SCrew, 5.4L, RoushCharger
CW
Old Jan 25, 2008 | 10:57 PM
ech0sh4y's Avatar
ech0sh4y
lol could be ur roush charger =P
Old Jan 25, 2008 | 11:33 PM
THE KING's Avatar
THE KING
If the intake was leaking air, then wouldnt the truck not run right becaue of a loss of vacuum?
Old Jan 25, 2008 | 11:34 PM
THE KING's Avatar
THE KING
Yet it wouldnt be leaking air it would be sucking air in right?
Old Jan 26, 2008 | 07:26 AM
Bigtony4's Avatar
Bigtony4
My 04 does it when it is really cold and I am going at a steady speed. As soon as I give it more gas it stops. If I slow down to a steady speed again it will come back! Only when it is very cold.
81-F-150-Explorer
Jun 10, 2009 09:10 PM
RussB
Apr 5, 2008 12:13 AM
Chilako
Nov 19, 2006 09:56 PM
deanroller
Feb 20, 2006 10:08 PM
