5 inch Exhaust
Old Dec 31, 2007 | 12:50 PM
mitchf2506.0's Avatar
mitchf2506.0
5 inch Exhaust
I have a 03 Ford F250 6.0 and I was wondering if I could straight pipe my truck with 5 inch turbo back? Will it thow any codes with no cat? What should I do with the o2 sensor?
Old Dec 31, 2007 | 12:54 PM
BGMSPD's Avatar
BGMSPD
There is no O2 sensor so no worry of any codes. And i don't believe the 5" downpipe fits without a lot of persuasion from a hammer or a jack agains the firewall.
and welcome to FTE. do a search on the exhaust and you'll find plenty of reading for days.
Old Dec 31, 2007 | 01:03 PM
mitchf2506.0
how far back will I have to beat back the fire wall? Is it a hard job to do all this?
Old Dec 31, 2007 | 01:07 PM
BGMSPD's Avatar
BGMSPD
i don't know, i have a 4" downpipe, but i've read about guys going larger and having to "adjust" the firewall in certain spots.
Old Dec 31, 2007 | 01:11 PM
mitchf2506.0
Dp you have four inch all the way back straight piped or do you have a muffler? Did that help with MPG?
Old Dec 31, 2007 | 02:43 PM
BGMSPD's Avatar
BGMSPD
I'm running a 304ss kit from mbrp turbo back with no muffler. i still have the cat in place for legal reasons. it seems to keep the egt's down a little with the programer and it's a little louder than stock.
i gotta clarify i have a 3 1/2 " downpipe that goes into the cat. after the cat it changes to 4" all the way out.
Old Dec 31, 2007 | 03:10 PM
GregsSD's Avatar
GregsSD
A 3-1/2" downpipe will fit easy, but a 4" downpipe needs some hammering or crimping usually to make it fit so I don't know how you would be able to fit a 5" downpipe at all or if anyone even makes a kit with a 5" downpipe.
There is no o2 sensor and removing the cat and muffler will not throw any codes.
Old Dec 31, 2007 | 04:27 PM
07psdrookie's Avatar
07psdrookie
Biggest you can do I believe is a 4 inch downpipe and get an adapter from someone like MBRP and run 5 inch from the downpipe back.
