429 pistons in 460?
12-25-2002, 01:29 PM
429 pistons in 460?
can 429 pistons be used in a 460? I have a set of them available and would grab them. But I know they are different c/r any other differences
12-25-2002, 03:08 PM
on
429 pistons in 460?
Nope, they are different, pin height I think.
Nick from the frozen north
1974 F-250 4X4
soon to be 429
dana 60 front and rear
12-26-2002, 07:24 AM
429 pistons in 460?
429 pistons will more than likley ruin your engine if used in a 460. 460 pistons in a 429 will give you low compression.
12-26-2002, 10:12 AM
on
429 pistons in 460?
Compression height on the 429 piston is 1.882" while the 460 is 1.76". The 429 piston would sit nearly an 1/8" further down in the cylinder.
12-26-2002, 12:43 PM
on
429 pistons in 460?
Oh, Do the math again. It will end up sticking out of the bore and above the deck .090 causing the valves to slap the top of the pistons.
12-26-2002, 07:57 PM
429 pistons in 460?
I thought there was differences. The guy that has them said he intended to use them in a 460. Thanks for your reply.
12-27-2002, 12:33 AM
12-27-2002, 04:09 AM
on
429 pistons in 460?
You are right, Mark. Dyslexic mathmatics from too much eggnog (smile). They'll stick out of the cylinders, not further down inside them.
12-27-2002, 08:08 AM
on
429 pistons in 460?
Hey I do the silly stuff all the time. As long as we have each other to watch the others back we will be fine. Besides ever weld an engine mount in backwards? I did once, you can imagine I am a firm believer in tach weld, walk away for a bit then come back, and look at it to make sure it is right.
chukar
07-28-2017 12:40 AM
abrojal
09-17-2016 11:59 AM
highoctane74
03-06-2011 11:50 PM
gabraham
06-16-2003 06:41 PM
429 ,
429460 ,
460 ,
57 ,
block ,
com ,
deck ,
difference ,
engine ,
ford ,
height ,
pin ,
piston ,
pistons ,
truck
