ABS Light on
Old Dec 31, 2007 | 11:08 AM
douthit's Avatar
douthit
4wd Low
ABS Light on
I have a '05 f250 and I recently installed an Edge Juice w/ Attitude. Now the ABS light will come on and stay on sometime during driving. Sometime it comes on almost immediately and other time after driving many miles. Sometimes if the cruise is on it slams the throttle for a second, the speedo needly swings wildly, cruise disengages and ABS light comes on and stays on.
The dealer replaced the Edge module and no change and I have removed the module and went back stock. Same problem. What's puzzling is that it didn't start happening till just after the Edge was installed. Coincedence?
The ABS light came on one other time early this spring. The truck has been to the dealer since then though.
Old Dec 31, 2007 | 11:38 AM
ripnlips's Avatar
ripnlips
I think it's a coincedence. My 05 ABS light stayed on and it took the dealer a couple of times to fix it. First they replace the tune ring in the differential then they found a faulty sensor and replaced it. Good luck.
