Can this be removed?
Old Dec 30, 2007 | 10:56 PM
pitbulls20's Avatar
pitbulls20
I was wondering if I could remove the houseing that the heater hoses and AC lines went to without losing my heat. I see where alot of trucks just have the heather hoses connecting at the firewall and the blower motor to the left of the hoses. I will try to post the picture that shows my engine bay and the part I am talking about is the black housing on the left side on the cab firewall.
Old Dec 30, 2007 | 11:00 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE !
Unless you retro fit the NON-AC heater..then
Nope,
This is what is behind it
Old Dec 30, 2007 | 11:01 PM
hummertires's Avatar
hummertires
no, you have an external heater core, you could possibly convert it to the in cab version though
Old Dec 31, 2007 | 09:45 AM
pitbulls20's Avatar
pitbulls20
So how hard is it to convert the hearter core to internal?
Old Dec 31, 2007 | 10:43 AM
Mil1ion's Avatar
Mil1ion
You have to basically make it an NON-AC truck
That masn welding in the sheet metal for the firewall to create the regular heater assembly.
This includes the interior pieces as well.
Old Dec 31, 2007 | 11:01 AM
pitbulls20's Avatar
pitbulls20
Ok thanks. So not at all easy.
Old Dec 31, 2007 | 12:18 PM
RNOVRIT's Avatar
RNOVRIT
Or, you could get an after market A.C. kit for the truck and keep your A.C. and heat registers in the same location and just have to patch the hole in the fire wall....
Old Dec 31, 2007 | 12:39 PM
77460f150's Avatar
77460f150
Check out this thread, I have done this twice on two different trucks. You can see some pics in my gallery's too. It's not really that hard to do. -Ed
https://www.ford-trucks.com/forums/2...ml#post1765539
Old Dec 31, 2007 | 01:23 PM
guitar_demon's Avatar
guitar_demon
so are those tin cans supposed to be there? (top left, bottom right in the pic) my engine has the one in the top left of the picture. i thought whoever owned it before me just did a really cheap rigging job or something
Old Dec 31, 2007 | 01:41 PM
Mil1ion's Avatar
Mil1ion
Yes they vacuum reservoirs and required for trucks with AC ,speed control,emissions etc
One would be sufficient with AC disconnected
Old Dec 31, 2007 | 11:41 PM
jimlj's Avatar
jimlj
When you remove the AC "box", it will leave a big hole in the fire wall. I cut a piece of the fire wall out of my donor truck when I removed my AC and put it in, along with the non AC heater. I would have liked to kept it but the turbo on my Cummins engine didn't play well so one or the other had to go. I plan to find a dealer installed AC system and add it back in using the factory dash vents.
Old Jan 1, 2008 | 08:34 AM
pitbulls20's Avatar
pitbulls20
well how much does this dealer AC cost and or how do I find one?
Old Jan 1, 2008 | 06:36 PM
RNOVRIT's Avatar
RNOVRIT
Around $850.00 and can be found at ACKITS.COM
Old Jan 1, 2008 | 07:08 PM
Duke78's Avatar
Duke78
I'm confused...what are you trying to do? Get rid of the AC or get rid of the AC system?
The reason i ask is because i have an AC truck, i removed the AC and lines along with the condensor. Just capped everything off. Still have heat, no leaks and no huge AC compressor in the way. Just wondering what the point of removing the entire core is...
Old Jan 1, 2008 | 07:36 PM
RNOVRIT's Avatar
RNOVRIT
He has a factory A.C. truck and wants to eliminate the bulky plenum assembly in the engine compartment. That contains the blower assembly, heater core and evaporator coil.
