Oil Pressure
Old Dec 30, 2007 | 04:50 PM
bad_habit59's Avatar
bad_habit59
Oil Pressure
95 f150 5.0 4X4 manual
Got my truck about a year ago and for the first few months when I would start driving the oil pressure gauge needle wouldn't move for the first 5-10 minutes of driving. Then it would pop into the normal range all of a sudden.
The oil pressure needle has never been above the "N" in the word NORMAL, so about 1/4 to 1/3 all the time. Just driving home today it would not come above the low line, not in the red but at the very bottom of the normal range. Its cold and snowy here so I haven't crawled under the truck but I am pretty sure there is no leaking oil.
Any ideas? Oil pressure problem or a faulty oil pressure gauge
Old Dec 30, 2007 | 04:53 PM
THE KING's Avatar
THE KING
I would say maby its an electrical sending unit? Im not sure if these are manual or electric simply because i havent look. But definatly see whats up with that, maby find where the sending unit screws in somewhere and hook a manual up just to make sure your oil pump and shot.
Old Dec 30, 2007 | 05:34 PM
quicklook2's Avatar
quicklook2
check with a mechanical gauge.
the one in your dash is an idiot light in drag.
Old Dec 30, 2007 | 05:45 PM
bad_habit59
how much is a mechanical gauge and how hard is it to do?
Old Dec 30, 2007 | 06:16 PM
Dean88's Avatar
Dean88
Mechanical guages are less than $20 bucks and aren't real hard to instal.
Old Dec 30, 2007 | 11:33 PM
bad_habit59
thanks for the help guys. I will do that next week
Old Dec 31, 2007 | 11:19 AM
TrevorP's Avatar
TrevorP
get yourself a decent gauge..
grab about a 4 or 6" extension with the npt threads on either end..also get a t fitting ..
thread the extension into the block and put he t on that, hook up the factory and your mechanical..dont do the nuts up too tight on the brass crush fitting or itll break and leak (someone could have told me that!) use thread sealer too
and have fun too
Old Dec 31, 2007 | 12:11 PM
quicklook2's Avatar
quicklook2
take oil filter off for more working room if you need it.
Old Dec 31, 2007 | 07:22 PM
TrevorP's Avatar
TrevorP
this i woud highly reccomend..if you dont take it off make sure there are no kids around because the swearing from frustation can flare up
Old Mar 1, 2008 | 01:10 PM
Petik's Avatar
Petik
hey guys, i'm looking at doing this myself now. can someone please post what thread/pipe sizes are involved in putting the T in place? also, is it possible to just replace the stock sender switch with a full analog sender that would just make your stock gauge become more useful?
Old Mar 1, 2008 | 06:26 PM
EPNCSU2006's Avatar
EPNCSU2006
All the fittings are 1/4 NPT. You can put a variable resistance sender in place of the switch, but you will also have to jumper the resistor on the back of the instrument cluster.
