Sponsored by: Auxito
Help
Old Dec 30, 2007 | 03:16 PM
riverrider's Avatar
riverrider
Help
Went to start this morning turned over, then stopped. Get clicking sound (sounds like a solenoid or relay closing) but nothing else. Lights work, radio works, etc. what should I check
Old Dec 30, 2007 | 03:20 PM
fire240's Avatar
fire240
I would check the battery first to see if it is good. If that is fine then check your cable connections.
Old Dec 30, 2007 | 03:23 PM
LxMan1's Avatar
LxMan1
What engine do you have? If a 4.2V6, pull the plugs, it may have a cylinder full of anti-freeze and getting ready to bend a rod.
Old Dec 31, 2007 | 01:46 PM
150mudder's Avatar
150mudder
Lxman does have a good point. also if you get past the point where you realize its not the coolant in cyl, then check the starter itself. get a hammer, have someone crak the motor and get under there and smak the starter. if it starts, then you need a starter.
