Air compressor Question for blasting
Old Dec 31, 2007 | 12:52 PM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Like I said above, I've known of two instances where plastic ruptured when used for air lines. One possible reason I see is that it has a tendency to sag. Condensation would collect in the sags, and if it froze, it'd go pop. I've also seen PVC get brittle over years of use. That could be another issue to deal with.
Old Dec 31, 2007 | 01:02 PM
brucelee's Avatar
brucelee
Forgot to mention in my eariler post that I used Sch 40 3/4 PVC with no problems in the last 10 years. Of course, I could be the exception. Here in Middle Georgia we don't get any long hard freezes so that may be something to it?
Old Dec 31, 2007 | 02:14 PM
49willard's Avatar
49willard
[QUOTE=rcav8or]I see black pipe and copper. Our old shop, years ago, had Schedule 40 PVC, and I was thinking about going with it. Any reason not to? It's inexpensive, held up just fine, and easy to change/repair...
IMHO stay away from PVC. The problem is brittle fracture and flying sharp shards. It is rated at zero pressure for gases (such as air) for exactly that reason. Water is basically an incompressible fluid such that it will not create the missles (shards) that compressed air would.
One concern is an impact problem should a heavy object fall onto the pressurized PVC. It is cheap and potentially very dangerous.
Old Dec 31, 2007 | 04:38 PM
DGMFORD's Avatar
DGMFORD
I have an Ingersoll Rand 60 gallon, 175 PSI, 5 HP - 11.8 Peak and 15.8 CFM@ 90 PSI. It will paint, blast, run a DA non-stop and blow up the occasional pool float for the wife. Bought this from Sears for around 500 bucks, reconditioned
Old Jan 1, 2008 | 08:34 AM
barbsbuddy's Avatar
barbsbuddy
I would not use PVC pipe for any air lines. There have been several horror stories about those line blowing out under pressure. They are not designed for that pressure. Black iron pipe or copper are safe. Check some of the threads in the garage and workshop forum.
There was an ad recently in Old Cars Weekly for for an air line system using flexible plastic tubing and specific fittings. It looked like a decent system for a smaller shop, as the lines were only available in 1/2' size. I could look for the ad if anyone is interested.
Diesel_Brad
Garage & Workshop
20
Oct 21, 2009 08:14 PM
aj197816134
Garage & Workshop
19
Mar 18, 2009 10:37 AM
Fourwheelinj1
Garage & Workshop
30
Oct 18, 2005 12:17 AM
randylay
Garage & Workshop
Mar 12, 2005 09:27 PM
tyminski
Garage & Workshop
19
Apr 25, 2002 08:32 PM
