Reading the posts, it seems the most likely problem is the shift motor as nothing happens when I engage the 4 wheel drive. However, I would think the 4x4 light would temporarily turn on when the truck is started and it does not. I do have power to the fuse box inside the cab, but when I shift the lever, there is no click, or light, or anything.
Anybody have any advice? Where I could find the wiring schematics? How is changing the shift motor?
The problem started today after I did some brake work and topped off the differential fluid. I just can't imagine the two are related.
The fuses all seem alright, but how many wiring harnesses are there to check. I see the obvious one connecting to the electric shift motor on the transfer case. I pulled this apart and it appears in great shape. Any others?
Today I pulled the electric motor off the transfer case and it works fine. I tested it by connecting the motor directly to the battery. The plastic cover that houses the dial with the electical contacts appears to be one solid piece, thus I was unable to check it. I think it may be time to bring it into a garage as I am tired of looking and thinking about the stupid thing.
