460 engine swap
Old Dec 29, 2007 | 07:56 PM
roothog460's Avatar
roothog460
460 engine swap
I have a 79 f100 short box, and im swapping 302/c4 with a 460/c6. other than motor mounts, what else would need to be swapped? i.e. radiator, ignition control, driveshaft.....
Old Dec 29, 2007 | 08:20 PM
Matts72's Avatar
Matts72
Ignitions are the same... distributors are different (the plug is the same though) You'll need a bigger radiator, the Modine 433 will work, its a 3 core. If you are racing or towing you will want the 4 core super cooling one, I don't have the part number handy. The crossmember for the tranny is different between the C4 and C6, you'll need one from a 2wd 302/351M/400/460 - C6 powered truck. You should also be able to grab that driveshaft.
You will also need exhaust and brackets to go with the 460, accesories should all be the same
