rear spring spacer
Old Dec 29, 2007 | 07:24 PM
ajjs's Avatar
ajjs
rear spring spacer
I have a 1987 f150 4x4 I6 4sp. I notice that there is 2'' spacer between the rear spring and the axle housing. Would there be any adverse effect on the drive
line or anything else if I remove these spacer and thus bringing the rear down? Thanks for any information.
Old Dec 29, 2007 | 07:35 PM
khadma's Avatar
khadma
Carpenter Local 745
That is a rear lift block used on 4x4s.
I would say there would be less problems than lifting the truck 8 inches.
Why are you planning to do this? Are you going to lower the front as well?
Or are you trying to level the stance of the truck?
Old Dec 29, 2007 | 07:49 PM
ajjs's Avatar
ajjs
I just want to level the truck and this looks like a easy way to bring the rear down some. I don't plan on any serious off roading or heavy hauling.
Old Dec 29, 2007 | 10:55 PM
95F350XL's Avatar
95F350XL
You will have to get shorter u bolts, and yes you can take it out. the 2wd doesnt come with the blocks.
