Offroad & 4x4
Clicking in the front end
Old Dec 29, 2007 | 10:14 AM
master_mechanic's Avatar
master_mechanic
When driving around with my hubs locked or when its in 4wd without the hubs locked i hear a clicking in the front end the hubs are new and so is the driveshaft i cant seem to figure it out because the 4wd works. btw the front axle is a dana 60 with a 4.10 posi. any ideas would be awesome
Old Dec 29, 2007 | 10:30 AM
Ryan50hrl's Avatar
Ryan50hrl
when your going straight? or turning? or all the time?
Old Dec 29, 2007 | 10:31 AM
master_mechanic
all the time doesnt get better or worse when i steer
Old Dec 29, 2007 | 10:33 AM
Ryan50hrl's Avatar
Ryan50hrl
hurm.....drive shaft u-joints or axle shaft u-joints going bad. When they're rotating you're hearing them bang around....
Old Dec 29, 2007 | 10:35 AM
master_mechanic
im leaning towards the axle shaft u-joints because the front drive shaft is new and so are the u-joints
Old Dec 29, 2007 | 10:40 AM
Ryan50hrl's Avatar
Ryan50hrl
what year of truck?
Old Dec 29, 2007 | 10:42 AM
master_mechanic
the axle is an 86 the rest is a combination of years
Old Dec 29, 2007 | 10:49 AM
Ryan50hrl's Avatar
Ryan50hrl
shaft joints......if its not that it could be something internal in the diff or could be the hub bearings.....but thats a long shot..
Old Dec 29, 2007 | 10:50 AM
master_mechanic
thanks alot i appreciate the help
Old Dec 29, 2007 | 11:01 AM
Ryan50hrl's Avatar
Ryan50hrl
no problem....let us know what it is when you figure it out.....and oh by the way....welcome to FTE.com
Old Dec 29, 2007 | 11:28 AM
master_mechanic
btw i forgot to mention last week when i had the front driveshaft out the truck stoped clicking wehn the hubs where locked and in 4wd without the drive shaft. is it possible that its somehting bad in the t-case that only happens when theres a load on it?
Old Dec 29, 2007 | 11:32 AM
Ryan50hrl's Avatar
Ryan50hrl
hurm.....it could be....but i'd check those ujoints in your driveshaft again.....is there a lift on this truck?
Old Dec 29, 2007 | 11:33 AM
master_mechanic
the driveshaft u-joints are all brand new last week and yeah theres a 6'' skyjacker lift in it
Old Dec 29, 2007 | 11:41 AM
Ryan50hrl's Avatar
Ryan50hrl
ahh...it could very well be just from the angle on the driveshaft ujoints....i know with a six inch lift your getting close to the max angle on those joints.....i used to have problems with those on mine. Still i'd check out the axle shaft joints....
Old Dec 29, 2007 | 02:58 PM
rebocardo's Avatar
rebocardo
It could be the shaft joints, but, I would double check that you put the hubs together correctly and the spring and spacers (bearings) and cam are correctly positioned.
I had a clicking before in my truck and it turned out when I swapped to Mile Marker I didn't line things up correctly and once I disassembled the hub the clicking went away.
