Sponsored by: Auxito
windw crank removal
Old Dec 29, 2007 | 10:03 AM
TUFFY's Avatar
TUFFY
windw crank removal
How do you remove the window crank on a 1997 model. thanks.
Old Dec 29, 2007 | 01:34 PM
LxMan1's Avatar
LxMan1
See if the outer cover is removable on the end away from the ****, then you should be able to get to a screw that holds it to the splined shaft.
Old Dec 29, 2007 | 01:43 PM
Silver Streak's Avatar
Silver Streak
Most window cranks are held on my a clip that slides into a notch in the shaft. If that's the case with yours, try wrapping a rag around the shaft behind the crank and pulling it around. The rag will usually catch on the clip and pull it out.
Old Dec 29, 2007 | 08:02 PM
triton_2002's Avatar
triton_2002
That's old school.........
The crank handle is a two part piece. Get a flat screwdriver on the edge of the shaft part and it should lift off the cover, which you can rotate out of the way, but don't pull it or you'll break it. Then you'll need a long torx driver to get the bolt that holds it down. If you need to pull the door panel off, pull it UP, not out (after removing the other screws that hold it)
Old Dec 29, 2007 | 10:32 PM
TUFFY's Avatar
TUFFY
Thanks for the replys.
