Transfer case replacement motor help
Old Dec 28, 2007 | 08:24 PM
truckmonger1's Avatar
truckmonger1
I have a '96 4.0 and the transfer case motor will not turn. I removed the unit from the transfer case and still nothing. I have the 4057 case I believe. The electrical connector is kind of square. Here is the pickle. I unplug the harness from the transfer case motor and there are 2 other sensors or something in the plug. I can't just unplug it and remove the motor to install a replacement. Do I have to unpin the connector plug wire by wire. If so, how. Thanks.
