recommendations
Old Dec 28, 2007 | 07:19 PM
bad_habit59's Avatar
bad_habit59
recommendations
you guys probably get this question all the time
I am looking for an exhaust uprgade for my 95 5.0 f150. I am looking for better power and better sound. I plan on slowly upgrading a little at a time. I hear some brands have exhaust systems that fit the oem exhaust and you can upgrade bit by bit. I am just looking for a middle of the road system that reflects that in the price.
thanks
Old Dec 28, 2007 | 08:34 PM
zpmps2's Avatar
zpmps2
Hack saw, cut them suckers off. OR do what i did <<read my sig, all under 300 bucks
Taylor
Old Dec 29, 2007 | 12:28 AM
godblessmud's Avatar
godblessmud
Cut it off and then build from there. Better to weld new stuff on as you go than have to keep chopping up your welds to add/change your system. Watch yourself with the cats if you live in an emissions testing area...
Old Dec 29, 2007 | 08:43 AM
busted's Avatar
busted
just my opinion, my 1995 with a 302 "s muffler and the cat under the cab had holes in them loud and was sick sounding its been straights for a year but i got a flowmaster super40 welded where the 1st cat used to be and a turndown right past the cab,sounds real good.still has another cat with a heat shield up closer to motor, but ive had glasspacks,thrush turbo tubes,and a afterburner turbo from oreilys on my old bronco and the flow sounds way better to me.on the f150.
ForceFA
All Things Towing
Apr 28, 2017 07:11 AM
KenRebF-250
Oct 31, 2016 10:45 PM
70T351W
6.7L Power Stroke Diesel
May 22, 2016 07:49 AM
justonv
May 27, 2015 10:29 AM
pb34
2004 - 2008 F150
17
Jul 11, 2008 10:51 PM
