Emissions Removed Need Help
Old Apr 11, 2000 | 08:32 AM
BillW's Avatar
BillW
Hi everyone,
I just recently became the owner of a 1980 F100 with the 4.9l(300). The body is nearly rust free, just a little over both rear wheel wells, and a bad repair on the drivers cab corner.
Anyway here is my problem, sometime in the past just about all of the emissions junk was removed. Engine has been strong the few weeks that I've had it, but we had a cold spell here last weekend and temps droped down below 40. Engine did not want to start after I stopped to put some gas in, and stalled again shortly after, had same problem with stalling after it had sat for about 3 hours. The only things that seem to be in place is the PCV,Heat to the Air Cleaner, and the vacuum to the distrubitor advance. I suspect that the carb likely needs rebuilt and the choke temp control replaced. Running very rich.
What really should be there to put things back the way they should be? Dealers around be want $100 just to look at it and give me a parts list.
We curently do not have emissisons testing here in Northeast Tennessee. If most junk is left off what really needs to be in place in order to run right?
Any timing changes needed, or anything else?
Need all the help and advice you can give. Thanks.
BillW
1980 F100 Custom Shortbed
300 I6 w/4spdOD Manual
(105,000 miles)
Old Apr 11, 2000 | 09:43 PM
nitro94's Avatar
nitro94
The most common reason for one of these engines running rich is a ruptured power valve in the carb. A new one will come in a rebuild kit. The lack of a opperational emissions system usually won't make it run noticeably bad. The choke system needs to function correctly also.
Old Apr 13, 2000 | 04:54 AM
BillW's Avatar
BillW
It has been suggested that I go to a pre emmisions carb, any idea of what carb I should use.
BillW
(105,000 miles)
Old Apr 16, 2000 | 10:52 AM
Thudpucker's Avatar
Thudpucker
Go to a Library, look in two places. First the Motor's manual section. Read the Specs for the different 300's. I think the Carb from a 69-78 will work.
Be sure it's a 300 Carb and not a 240. The Jet is different, and will burn the Plug's and Valve's if you get a 240.
Second place to look is in the Reference section for the Emissions information. That will tell you what your truck was supposed to have.
I can't for the life of me, understand why people removed that stuff. It worked just fine with it installed. My 81 Bronco had just a few heat related vacuam valves, and the Cat. It got 13-15 mpg and had plenty of power. I pulled a 23' Tolly Craft on a tandem wheel trailer all over Alaska. Did just fine. Had to shift down sometimes but most of it was done in Fourth. I would like to have had an overdrive.
Old Apr 18, 2000 | 08:51 PM
Jim_V's Avatar
Jim_V
1980Bronco4.9L300
1978 - 1996 Big Bronco
17
Dec 30, 2015 03:17 PM
towsrus
Oct 26, 2011 09:57 AM
fordbeast_80
Mar 25, 2011 05:05 PM
DOHC330MustangGT
Sep 9, 2007 07:48 PM
sc0tty8
Oct 25, 2006 09:52 AM
