Distributor cap Help!!
Old Dec 28, 2007 | 01:06 PM
boggerted's Avatar
boggerted
Im tryint to replace my distributor cap, and I accidentally put the wires 180* backwards. So, I need to start from scratch. Where does each wire go on the cap? I need help!!
Old Dec 28, 2007 | 02:44 PM
chrisf250-460's Avatar
chrisf250-460
i believe the firing order is 1,3,7,2,6,5,4,8
4 8
3 7
2 6
1 5
front of engine
Old Dec 28, 2007 | 03:18 PM
boggerted's Avatar
boggerted
Thanks I was able to get it using your info. I REALLY appreciate it!! Also, what are some conditions of late timing? Mine carks easy but takes a while to catch, idles very rough and sluggish, and has low vacuum.
Old Dec 28, 2007 | 03:48 PM
Franklin2's Avatar
Franklin2
No need to guess, just buy or borrow a light and check it.
Old Dec 28, 2007 | 04:37 PM
boggerted's Avatar
boggerted
I tried using a timing light, but even after sanding and degreasing the balancer, I couldn't find the marks. Are there just lines or numbers written on it? Do you have any pics of the marks so i can maybe find them?
Old Dec 28, 2007 | 05:44 PM
Franklin2's Avatar
Franklin2
There is a whole bunch of numbers and marks on the ones I am familiar with. And a single pointer mounted on the timing cover. Make sure you put the light on the passenger side front spark plug wire.
Old Dec 28, 2007 | 06:40 PM
boggerted's Avatar
boggerted
On mine I saw 4 marks on the balancer and a round thing and a "pointer" on the timing cover. Your saying I should use the pointer?
Old Dec 29, 2007 | 10:32 AM
Franklin2's Avatar
Franklin2
Point the timing light at the pointer, and one of the marks on the damper will line up with the pointer when the light blinks.
Old Dec 30, 2007 | 09:42 AM
boggerted's Avatar
boggerted
ok another question. My dizzy is pretty siezed and I dont want to hit it or force it, any good tips on freeing it up? I already sprayed the base with PB and scrubbed it clean with a wire brush.
Old Dec 30, 2007 | 10:31 AM
beaners1's Avatar
beaners1
I've had several get stuck, only have had luck getting 1 loose. Like you said spray it with a good penetrating fluid, let it soak, tap on it lightly and let it soak some more if needed. A couple of mine made me so mad I just broke them off and repalced them.
If you need to pull it up, put some anti sieze on it.
