new guy here
Old Dec 28, 2007 | 07:26 AM
pavermanter's Avatar
pavermanter
new guy here
hi everyone, first time post here. I have a quik question, I have a 05 scab stx with the 4.6 , just changed my oil, (mobile 1, 5w20 dumped 5 quarts in ran it a bit, let it settle some, checked it again and it's not on the stick... whats up with that? this is the first fourth change i've done on her, and first time that ever happened. and yes the plug is in( hehehe) no leaks. they we're outta all filters but fram truegaurd, i would know why that would matter though.
Thanks in advance
Old Dec 28, 2007 | 07:41 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
Thanks in advance
First Welcome to the FTE . I would double check your oil capacity. My 04 4.6L takes a little over 6 quarts of oil to registar full on oil dip stick.
Mike
Old Dec 28, 2007 | 08:18 AM
black04lariat's Avatar
black04lariat
Mike
x2.. My 04 5.4 takes 7qts. Check your manual for proper amounts. If you dont have one go to www.fleet.ford.com and check under the maintenance tab and you will find owners manuals you can get.
Old Dec 28, 2007 | 08:31 AM
05Edge's Avatar
05Edge
My 04 4.6 manual says it takes 6 quarts, and the shop I took it to actually put in 7 and it was right on the full line...
Old Dec 28, 2007 | 08:34 AM
pavermanter
thanks guys, i realize 5 qt's is short, but thats just where i usually start checkin it up to proper level. normally it begins to at least show on the stick with 5 qt's. again thanks to all
Old Dec 28, 2007 | 09:01 AM
Frd67cobra's Avatar
Frd67cobra
Yup, 6 quarts it is... 5 for the motor, 1 for the filter. Hey 05Edge, 7 FULL quarts? Are you sure it's not overfilled?
Old Dec 28, 2007 | 11:02 AM
05Edge's Avatar
05Edge
I can look again, but I saw the stick. and it was on the max fill line... maybe I need to look again. The guy said that some assembly plants use a bigger pan, now I'm doubting myself. I can say this, if it's overfilled, then I can scratch that lube place off the list. I could just do it myself, but I never have any time anymore!
