Throttle Body for 300's!
Old May 15, 2000 | 08:17 AM
grazier1's Avatar
grazier1
Well I pretty sure this will work, but I haven't tried it yet. I have done some extensive research and I have found the throttle bodies for the 4.9L, 5.0L, and 5.8L Ford engines for 1994 and 1995 don't differ other than the way they set on the intake manifold (according to the Chilton's manual that covers these years and actual visual inpection of a 4.9L and 5.0L engine). Here is my idea! BBK/Edelbrock make a Twin 56mm (#3837) and 61mm (#3838) High-Flow Replacement Throttle Body for the 5.0L and 5.8L EFI engines. I talked to the tech service at Edelbrock and was told the only reason why the don't list the 4.9L as compatible is they haven't tested it. Has anyone tried putting one of these Edlebrock throttle bodies on their Ford 300? I don't forsee any problems other than maybe a lean fuel/air mixture. I'm pretty sure it will work! Anyone have any comments on this before I try it out?
Old May 15, 2000 | 04:13 PM
StrangeRanger's Avatar
StrangeRanger
I contacted Edelbrock with the same question about 2 months ago, they said it would not fit. I guess it depends on who you talk to.
Old May 16, 2000 | 05:28 AM
TallPaul's Avatar
TallPaul
Go buy a mounting gasket for a 300 throttle body and for a 302 and 351, then compare them. Better yet compare them at the parts store and don't bother to buy them. Then you will know if it will fit.
Old May 24, 2000 | 09:04 AM
PAUL_2's Avatar
PAUL_2
Old Jun 2, 2000 | 02:49 PM
Eddie's Avatar
Eddie
I was just surfing the "Forum" section at www.cliffordperformance.com, and there is a very interesting thread on this very subject.
Eddie
magnumcccc
73
Apr 15, 2026 08:15 AM
640 CI Aluminum FORD
2009 - 2014 F150
67
Jul 19, 2021 08:41 PM
Harabec
19
Feb 17, 2021 10:43 AM
Meep120299
Nov 8, 2015 03:25 PM
gov2mod
1978 - 1996 Big Bronco
Aug 15, 2004 06:07 PM
