heater doesnt work but defrost does?
Old Dec 27, 2007 | 08:38 PM
guitar_demon's Avatar
guitar_demon
i have a 78 f250, if i turn the heat on and drive into town (15-20 min) when i get into town my cab is still freezing even though the gauge says the engine is warm. yet if i turn the defrost on the cab warms up in about 5 min. im not extremely mechanical and dont know what to look for. any help would be appreciated. thanks
Old Dec 29, 2007 | 06:02 PM
Ultramagdan's Avatar
Ultramagdan
If this has a water valve on it I would check there first. With the heat on both hoses should be hot. If it's not you have a problem.
Old Dec 30, 2007 | 05:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
With or without A/C?
With A/C: There's a blend door vacuum control valve (19B888) mounted behind the control panel. When you move the selector lever to heat, the valve closes the defroster door, and opens the heater door. The valve may be the problem.
With A/C: Each blend door has a vacuum motor (18A318) on it. The motor that operates the heater blend door may be defective.
Without A/C: The cable that operates the heater door is either not hooked on, or the blend door itself is stuck. What usually causes the door to get stuck, is something (like a pencil) falls thru the defroster ducts on the dash, works its way into the heater plenum chamber (heater box) and jambs the door.
The vacuum controlled heater water valve (if so equipped, not all trucks have it) is working (that's amazing in itself, cuz the valve is a POS!), because heat is going thru the defroster ducts).
Old Jan 29, 2008 | 08:58 PM
okie ford's Avatar
okie ford
Its all ran by vacuum.
What you described happened to me twice in my 76 F-150, 390. First time was the selecter switch (vent-AC-HILO) in the dash went bad, second time it was only a stopped up vacuum line. Check for leaks.
LOVEMYLABXS
Aug 31, 2014 06:35 AM
marcs724
6.7L Power Stroke Diesel
51
Jan 16, 2013 10:04 AM
Shanemh
1983 - 2012 Ranger & B-Series
Jan 30, 2011 05:50 PM
cobrar97
6.4L Power Stroke Diesel
21
Nov 21, 2010 11:38 PM
devilsword
General Automotive Discussion
17
Nov 22, 2005 06:06 PM
