<TABLE><TBODY><TR><TD vAlign=top width="100%">I have my truck back in the shop again. I had it in initially to fix a toe in /out problem where the tuck did not center steer and pulled really bad to the opposite direction the wheel was canted to. When I bought it back in yesterday the service advisor informed me that the supervisor had driven my truck and it was fine. It came out exactly opposite of what it went in for. He stated you are never gonna get a steering wheel to be exactly straight. I told him I just bought a 55k vehicle and you are telling me the steering wheel should be off 3-4 minutes and constanly pull to one side or the other? It actually feels like the steering box is loose, as the truck also seems to wonder. Well they took it back and said they would "check it again and go from there" Can any of you give me any advice on this? My 05 6.0 never had these problems, so I don't understand why is he telling me this is nomal.
<table><tbody><tr><td valign="top" width="100%">I have my truck back in the shop again. I had it in initially to fix a toe in /out problem where the tuck did not center steer and pulled really bad to the opposite direction the wheel was canted to. When I bought it back in yesterday the service advisor informed me that the supervisor had driven my truck and it was fine. It came out exactly opposite of what it went in for. He stated you are never gonna get a steering wheel to be exactly straight. I told him I just bought a 55k vehicle and you are telling me the steering wheel should be off 3-4 minutes and constanly pull to one side or the other? It actually feels like the steering box is loose, as the truck also seems to wonder. Well they took it back and said they would "check it again and go from there" Can any of you give me any advice on this? My 05 6.0 never had these problems, so I don't understand why is he telling me this is nomal.
</td></tr></tbody></table>
wow I would look for a new steeler........those guys can't be trusted
On my 05 F350 I encountered tread separation on the front once. The way to check for it is to swap the front tires to the opposite side. If you have this it will pull the same amount in the other direction.
