Sponsored by: Auxito
Tire Size - Width
Old Dec 27, 2007 | 06:52 PM
bigun72's Avatar
bigun72
Question Tire Size - Width
I got a 99 f150 , and im in the process of liftin it , and the tires im lookin at r 15.50" wide , will that affect my turn radius ? and will they rub the frame when i turn ? if so , wat size backspacing on my wheels will i need ?
thanks for all the help
Dustin
Old Dec 27, 2007 | 09:15 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Yeah...I'm betting you will rub. What size lift and tires are you installing? 10" or 12" wide wheels?
A 10" wide wheel with a 4" backspacing might be the best choice regarding frame rub...but it will increase your chances of rubbing the bumper and rear inner fender though. Stock backspacing is 4.5"
Old Dec 28, 2007 | 04:29 PM
bigun72's Avatar
bigun72
im gettin 16x10s rims , and gonna have a 3" body and a 4" suspension lift , with 38x15.50 ground hawgs .......
thanks bud
Old Dec 29, 2007 | 01:05 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
7" of lift and 38" tires will be pushing the limits. Most people run 35's with 6" of lift and come close.
Old Dec 31, 2007 | 06:36 PM
bigun72's Avatar
bigun72
well i got just a 3" body lift on now , and sum 35s and i cud go bigger now , so shurly a 38 will fit with 4" more inches of lift , wudnt u say ?
Old Dec 31, 2007 | 08:16 PM
adeese_660's Avatar
adeese_660
If you stay around 4 1/2 to 5'' of backspacing,you should be fine,you may get a very small amount of rub at full lock,but nothing to worry about
Old Jan 1, 2008 | 10:18 AM
bigun72's Avatar
bigun72
ok thanks bud preciate it .......
Bigun
