Having a problem starting my 94 f-150. At times engine turns over fine but will not start. Used my code reader and found 1 code, 211. IT will start ok for a week or so and then won't start, keep trying and it will eventually start. Every so often it will cut off going down road . Is this code my problem or something else. Thanks for any help.
Eddy
*Verify all radio and condenser installations. Carefully follow manufacturer's installation instructions regarding the routing of antenna and power leads.
If no to above then more than likely you have a bad PIP sensor in the distributor or TFI (ICM).
