M50D shift plug problem.....HELP
Old Dec 27, 2007 | 01:51 PM
jmonintwo's Avatar
jmonintwo
Hey guys....changed the shift plugs in my 1990 I6 4.9 with the M50D manual transmission...they were defintly leaking....I followed the tutorial but have run into a problem. After I replaced the plugs I put the aluminum housing cover back on the tranny...fit like a glove. Installed the shift lever....went in just fine. Problem is, I can't get it to shift. I turned the truck on to see if that would help, let off the clutch and it started rolling, so it's in gear, but the shifter won't move it through any gears...help
