Carburator Tuning
Old Jun 7, 2000 | 08:35 PM
brianbek's Avatar
brianbek
Carburator Tuning
i have a 1980 f150, with a 300 and a 1 bbl carb,
the truck was sitting for a while, but now it runs
smooth with power to spare most of the time, but i
can't seem to get the gas\air mix right, and i've
tried and some times get good speed but poor acceleration, or excellent acceleration with no power once i get up to speed. any tips on how to tune the carburator?
Old Jun 18, 2000 | 07:41 AM
pbr12pak's Avatar
pbr12pak
Carburator Tuning
I, always just set mine with a vacum gauge, you might wanna check for a loose carb or intake if it is changing on you if you not sure how to do it e-mail me at pbr12pak(No Email Addresses In Posts!) and i will let you know
Old Jun 27, 2000 | 08:00 AM
Raul's Avatar
Raul
Carburator Tuning
pbr12pak: Why invite numerous e-mails? (like one more from me). Just post the explanation here and we can all learn. How do you tune a carb using a vacuum gauge?
Thanks
Old Jul 8, 2000 | 06:34 PM
scar's Avatar
scar
Carburator Tuning
You might change your fuel filter too. My 86 would run well up till about 2500 rpm then fall flat on it's face. Then sometimes it had a hard time pulling at all. With nearly 250,000mi I figured it was rebuild time. Somebody said it might be the filter and sure enough that fixed it.
This is only the second filter I put on it since new.
Old Jul 8, 2000 | 10:52 PM
nitro94's Avatar
nitro94
Carburator Tuning
Raul: You can tune a carb. with a vacuum guage this way. Turn idle mix screw in until RPM drops off ( vacuum will also drop) then turn screw out until you get highest and steadiest vacuum reading and smoothest idle quality.
Old Jul 8, 2000 | 10:57 PM
cale's Avatar
cale
Carburator Tuning
51M1
Oct 21, 2016 06:35 PM
projectdagger
Aug 30, 2007 09:58 AM
whalerron
Modular V8 (4.6L, 5.4L)
Jul 18, 2006 10:01 AM
quehele
Dec 23, 2005 06:50 PM
gsadow
Mar 27, 2001 07:23 PM
