1991 f150: IFS or solid front ?
Old Dec 27, 2007 | 12:25 AM
fast68's Avatar
fast68
in 1991 were the F-150 solid?
or IFS front ?
when was it changed?
trying to figure up an estimate on labor for replacing all the ballljoints on one of these
thanks for anything
Old Dec 27, 2007 | 12:42 AM
dixokai's Avatar
dixokai
I don't know for sure when the change was, I think 1980 ish. 91 is IFS though.
Old Dec 27, 2007 | 01:12 AM
hawaiian-style's Avatar
hawaiian-style
79 was the last f150 with solid axles.after that was ifs.
Old Dec 27, 2007 | 03:42 PM
fast68's Avatar
fast68
oh ok so 80 and up IFs
i read on wikipedia that throguh about 86 they were axle tube version but were hinged and the center housing was bolted to the chassis and they could be either coil or leaf ?
so not CV joint shafts yet ?
whats a good labor cost for replacing balljoints on a 91 ?
on this style do you have to pull the knuckles off and press the balljoints with the knuckles removed, or no ?
im trying to figure out what these are exactly
thanks again!
Old Dec 27, 2007 | 04:15 PM
Conanski's Avatar
Conanski
Almost. The 87-96 F150 had the Twin Traction Beam(TTB) front suspension, there are a pair of hollow beams cris-crossing the front, the front diff is mounted on the drivers side beam, and there are old style drivehafts with U-joints out each side to the spindle.
No, CV joints and A-arm front suspension didn't come until the next F150 redesigned in '97.
whats a good labor cost for replacing balljoints on a 91 ??
You have to completely dismantle the hub assembly to reach the bare spindle, the ball joint body is pressed into the spindle, the shaft is pressed into the TTB arm. Figure on 2-4 hrs per side R&R with all the right tools on hand.. wheel bearing socket, 3/4 drive socket set and ratchet or impact gun, ball joint press, possibly torches.
Old Dec 27, 2007 | 04:22 PM
flareside_thunder's Avatar
flareside_thunder
Edit...80-96 Had the TTB front Dana 44 setups......
JR
