FE Motors
Old Dec 26, 2007 | 06:57 PM
C-Mertens's Avatar
C-Mertens
FE Motors
I have a 1974 Ford F-250 Ranger XLT 4x4 with a 390 motor. I was taking apart my 390 and getting ready to take it in to get machined when I found a crack in the cylinder wall. I want to keep the 390 but those are hard to come by. Can I take a 352 or 360 bare block and put the 390 internals with little modification?
Old Dec 26, 2007 | 07:08 PM
9d4's Avatar
9d4
From what I am hearing you can. I belive the only dif is the bore and stroke. So (I THINK) by putting a 390 crank and rods in a 360 you have a 390???
Old Dec 26, 2007 | 07:10 PM
JBradley500's Avatar
JBradley500
you can with the 360 for sure...go to the FE section and read around there because they wont lead you in any wrong directions.
Old Dec 26, 2007 | 08:07 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site.
Since this is an FE engine only topic please allow me to direct you to the FE engine
forum where FE engines are discussed
https://www.ford-trucks.com/forums/forum51/
FTE is huge and has a forum for practially every specific topic.. feel free to look around the site for all the forums.
Old Dec 26, 2007 | 11:20 PM
ford390gashog's Avatar
ford390gashog
A 360 is the same bore. You can use that.
Old Dec 27, 2007 | 07:12 AM
highboy1975's Avatar
highboy1975
only difference between the 360 and 390 is the crank and rods
Old Dec 27, 2007 | 09:27 AM
Madmike33's Avatar
Madmike33
The rotating assy is the same. Only thing I'm curious about though is if that motor has been changed before? I'm pretty sure Ford wasn't putting 390s in the 74s. Check the stroke it might be a 360. Its the only way to differ the 360 and 390. I'm just looking out for you before you start buying 390 stuff that won't be right. Most people convert there 360s to 390s. Look into the FE forums. They're the Gurus, I'm there a lot for my own.
Madmike33
Old Dec 27, 2007 | 09:43 AM
FTE Ken's Avatar
FTE Ken
FYI, FE discussion is welcome in this section (these trucks have them), or in the FE section. If you have questions about this or other policies please feel free to contact the staff via User Feedback so you'll get accurate information. Thanks.
Old Dec 27, 2007 | 12:29 PM
C-Mertens's Avatar
C-Mertens
The Motor in the truck orginally had a 360 in it, but has been changed, I measured the stroke of the motor and it was 3.78" which is a 390 and the block is painted green which I have been told is a remanufactured block
Thanks for telling me about the FE forum, it has been alot of help, haven't spent alot of time on hear spend most of my time workin' my Ford truck.
and Thanks for all the help
Old Dec 29, 2007 | 06:44 PM
76f350spercamprspeal's Avatar
Smile 1976 Ford F-350 Super Camper Speacial RangerXLT 390 V8 4 on the floor.
Hi, evreybody
I want to know what the hoarse power on my 390 is? Can you please help me??
your friend.
76f350spercamprspeal.
Old Dec 29, 2007 | 08:04 PM
Mil1ion's Avatar
Mil1ion
Your 390 can't talk cause it hoarse ?
The Horsepower/Torque specs can normally be found in the FE engine forum
360 = FE engine
360
The 360 (of 360.7 in³ or 5.91 L displacement) was used in the F Series trucks and pickups. It is basically a destroked 390 with a bore of 4.05 in (103 mm) by 3.5 in (89 mm) stroke. The 360s were known for having sluggish performance because of the truck camshaft, mostly noticed by F100-F350s. Use of a standard 352/390 cam for use in passenger cars along with carburetor and distributor adjustment gave it the same kind of performance as the 352/390 car engines. First introduced in 1968 and phased out at the end of the 1976 year run. Rated at 215 hp (160 kW) at 3600 rpm (2-barrel carb, 1968).
Old Dec 29, 2007 | 08:05 PM
STGFordCrazy04's Avatar
STGFordCrazy04
This may help.
CI bore stroke
332 = 4.00" X 3.30"
352 = 4.00" X 3.50"
360 = 4.05" X 3.50"
390 = 4.05" X 3.784"
406 = 4.13" X 3.784"
410 = 4.05" X 3.984"
427 = 4.23" X 3.784"
428 = 4.13" X 3.984"
Old Dec 30, 2007 | 04:02 PM
Alvin in AZ's Avatar
Alvin in AZ
Originally Posted by Mil1ion
The 360FEs were known for having sluggish performance because of the truck camshaft... Use of a standard 352/390 cam for use in passenger cars along with carburetor and distributor adjustment gave it the same kind of performance as the 352/390 car engines. First introduced in 1968 and phased out at the end of the 1976 year run. Rated at 215 hp (160 kW) at 3600 rpm (2-barrel carb, 1968).
There's a lot of truth to that except the 360FE's main problem is from the lack of compression and pistons available to bring up the compression.
I've been hangin' out on the FE forum, can you tell? ;)
Alvin in AZ
Old Dec 30, 2007 | 04:26 PM
Redmanbob's Avatar
Redmanbob
The 360 can be used but be sure to have it power honed or bored as the stroke on a 390 will push the rings into the ridge on a 352/360 core with a 3.5" stroke. That would be bad,...
Old Dec 30, 2007 | 04:28 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
You can also have the cyl sleeved. Runs about $100 a hole here. Might be a easy alternative if you have no other blocks close by to pick from. Even with a good used block you'd need to mag and pressure test it. Then whatever machine work it needs. Also the cost of the block too. If you do the sleeve just find a GOOD shop that can handle it. If the rest of the block is nice and it's not been bored to death it's something to thnik about.
http://www.customdesignperformance.c..._sleeving.html
This shop is in my area. You can get an idea of what's involved.
