Cali Truck
Old Dec 26, 2007 | 02:59 PM
blake 7.3L's Avatar
blake 7.3L
Cali Truck
How can I tell if my truck is a Cali truck. Is the only difference the injectors or is there more to it? Would the vin # tell me, because mine was made at the Kentucky plant.
Old Dec 26, 2007 | 03:51 PM
Todd525's Avatar
Todd525
llok at the fuel pump. if it looks like the enterprise from star track, then its a cali truck
Old Dec 26, 2007 | 07:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Like this one:
Old Dec 26, 2007 | 07:17 PM
1997F-350's Avatar
1997F-350
if your truck is the same as the first 3 pics then you got one. another way is to pull the ebrake and get the pcm code but that is harder. or you can look at the sticker on the front of the hpop res for you inj code.
cali truck
Old Dec 27, 2007 | 07:41 AM
blake 7.3L's Avatar
blake 7.3L
Thanks guys I will check into it and let you know.
Old Dec 27, 2007 | 11:17 AM
blake 7.3L's Avatar
blake 7.3L
Stupid question!
Where is that located? Is it down under the FPR? A picture would help. I looked at the ones from RÖENTGEEP but I can't tell where it is located.
Thanks!
Old Dec 27, 2007 | 12:16 PM
FFemt5287's Avatar
FFemt5287
well, the fuel pump on a cali is basically right under the turbo. look behind the fuel bowl and whammo, should be right there on the engine valley. good luck.
-Brandon
Old Dec 27, 2007 | 12:35 PM
250turbo's Avatar
250turbo
do not go by hpop sticker code
Old Dec 27, 2007 | 12:38 PM
blake 7.3L's Avatar
blake 7.3L
Ok mine looks like the one in the picture except it does not have the black disk that says Bosch 401 240 169. Is this what makes it a Cali truck or do I have one?
Old Dec 27, 2007 | 01:24 PM
Todd525's Avatar
Todd525
Then I would venture to say that you dont have a cali truck. Unless someone has replaced that pump before. The only way to tell for sure is to run the vin number.
Old Dec 27, 2007 | 01:26 PM
ltfox's Avatar
ltfox
If a dont have the disc then you dont have the cali truck. Another check is the sticker on the valve cover.
Old Dec 27, 2007 | 01:46 PM
blake 7.3L's Avatar
blake 7.3L
Thanks guys I will check the fuel pressure to see if it is higher like on the Cali trucks. If not I am going to shim the FPR. What would the sticker on the valve cover say if it was a Cali truck?
Old Dec 27, 2007 | 02:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Originally Posted by blake 7.3L
Stupid question!
Thanks!
There are not stupd questions. You can see a pic in the post of 1997F-350 in the motor right under the turbo
Old Dec 27, 2007 | 02:32 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
this one
click in the picture to enlarge
Old Dec 27, 2007 | 02:37 PM
blake 7.3L's Avatar
blake 7.3L
Thanks that helped, but mine does not have the black disc.
