Carburator problem?
Old Sep 8, 2000 | 06:31 PM
warthog299's Avatar
warthog299
Carburator problem?
Hello all. I have a 1985 f-150 with the 300 CI six. I put a new carb on the truck and it runs great, idles nice and smooth but one problem. After running for about 5 or ten minutes the truck acts like it is running out of gas or running on 3 cyclinders. Do you think maybe a little dirt got into or is getting into the carb. I replaced one fuel filter and will do the other one tommorrow. The timing is good and I put new plugs in a couple months ago but will check them tommorrow too. What do you all think? PLEASE HELP!!!!!! Thanks. Greg.
Old Sep 8, 2000 | 08:19 PM
carlos57's Avatar
carlos57
Carburator problem?
I had a base gasket on a carb give me grief similar to your problem on a 1967 240ci 6 cyl. Had a manual choke and was able to get it to run when choked. I would be sure that you have not warped the carb and it stays tight after warming up. You may have to replace the gasket.
Good Luck
Greg
Old Sep 12, 2000 | 05:43 PM
carlos57's Avatar
carlos57
Carburator problem?
