Could copper plugs fix my problem
Old Dec 24, 2007 | 09:58 PM
Bigred1995's Avatar
Bigred1995
I am running autolight double platinum plugs in my 1995 5.8. I have what almost feels like a miss. When at a light in drive the motor has a slight stumble. It also happens when you accelerate lightly. I have already put in 9mm wires, cap and rotor, high output coil, k&n fipk, 3" exhaust with flowmaster and high flow cat. Could putting in copper plugs fix it or should I be looking for a cracked plug or wire or even a fuel issue?
Old Dec 24, 2007 | 10:04 PM
paintslinga2010's Avatar
paintslinga2010
I have the same motor and im running auto lite platinums. IT kinda does the same thing at idle so im gonna switch to copper plugs and see if that helps. And to think i thought i was doing my truck good spending extra cash on it...
Old Dec 24, 2007 | 10:05 PM
95F350XL's Avatar
95F350XL
Did you ck to see if you mixed a wire up?
Old Dec 24, 2007 | 10:13 PM
quicklook2's Avatar
quicklook2
use copper motorcraft plugs.
if you insist on motorcraft plats. only use the single electrode ones.
