Transmission interchange help needed...
Old Dec 24, 2007 | 09:39 PM
nofortunateson's Avatar
nofortunateson
Will a 5 speed from a '98 Ranger 2.3 bolt up to an '87 Ranger 2.9? Both vehicles are 2WD. (I would imagine the flywheel is definitely different) Thanks.
Old Dec 24, 2007 | 09:46 PM
frankenbroncoII's Avatar
frankenbroncoII
no. the 2.3 has its own bell housing bolt pattern. and the 98 bell is not removable being its a m50d. now, the trans from a 4.0L will swap being its the same block (basically) as the 2.9L.
Old Dec 25, 2007 | 08:22 AM
nofortunateson
Thanks for the info...
I guess I will start looking for a trans.
Old Dec 26, 2007 | 12:41 AM
Pablo-UA's Avatar
Pablo-UA
You may look for a bellhousing. There are bad 5st trannies on junkyards. Swap a bellhousing only. These trannies do not differ inside.
Flightwheel of 4.0 is a bit bigger, not sure about pressure plates and disks.
I have 3.0 Aero converted to 5st tranny and 4.0 SOHC ranger. Starters are different too.
The really unique engine is 3.0. No interchangebility with all other engines. To install 5st tranny on it I used bellhousing of auto tranny. Drilled some holes to bold it on tranny.
