I've read where guys buy straight pipe kits off e bay or from a sponsor..4 in...do these bolt to the clamp just before the cat or are the welded or what ?
I don't have a welder so I'm looking for ease of install etc....
Any help or suggestions ?
They are turbo back not cat back from Mko, unless you have a early 99 you don't have a cat on your truck, if you do get just remove the cat and it will bolt right on.
Im sure MKO has a cat back too..ether way it will fit your truck..they come for a long bed crew cab..you will need to cut a section out if you have a shorter wheel base truck....
