Here We Are Again. Setting Still Shifter In Drive With Foot On Brake
Buzzing And Or Viberating. Only When Could Outside. Surely
Someone Has Had This And Has Gotten It Fixed.
Mine does it, only fix that helped was adjusting the air intake where it mounts to the inside of the fender. Seems quieter now. I also found my bug visor loose, it was vibrating and making a buzz. Engine has slight rough idle when cold so I think it was just these items buzzing.
When its cold outside that is the only time it will do it. Just say your sitting at a
stop light in drive with your foot on the brake. You will here a buzzing sound
coming from the dash.If you move the shifter up or down the buzzing will stop. Just
by pushing the shifter button slightly move the shifter the buzzing tone will change.
Its not the ash tray got it fixed. And the shifter cable is ok had it checked said it
was out of one of its bracket
