divorced/married
Old Dec 23, 2007 | 12:42 PM
sedly's Avatar
sedly
divorced/married
im learning,i will assume that divorced is the transfercase is separated from the tranny?
Old Dec 23, 2007 | 12:58 PM
Mrcorey5's Avatar
Mrcorey5
Yes, Basically the divorced set-up uses a 2wd tranny and couples it to a remote mounted t-case with a small driveshaft. Most commonly found in the F250 high-boy series trucks. You might try searching the high boy threads to get more info and answers if you need them.
Old Dec 23, 2007 | 01:07 PM
sedly's Avatar
sedly
thanks Mrcorey5,thats all i needed on that question.both the tranny and the transfer case should have tags to specify exactly what they are?
Old Dec 23, 2007 | 01:21 PM
Mrcorey5's Avatar
Mrcorey5
Yes, just look for a stamped tag bolted to the unit. There is a thread post about some one with a divorced conversion, he posted alot of pics, check it out when you get a chance. I just posted on it so it should be at the top of the list
Old Dec 23, 2007 | 01:27 PM
sedly's Avatar
sedly
already on it, thanks again.
