had questions needed answers
Old Dec 23, 2007 | 07:29 AM
Super Dave's Avatar
Super Dave
My name is Dave, From outside Phila. (Newtown Sq.)I have a
"98" windstar
"88" f-250 custom (plow truck) 460
"96" f-450 super duty (12 ft. stake body dump) 460
"05" f-350 Pick up (powerstroke) plow truck
Had some MEGA problems with my "88" but thing it might be OK now.
I got on this site to find some answers, saw 4 other guy's having the
same problems, and after spending a ton of cash thought I would
let someone find out what the problem was and pray they would tell
the rest of us.
Old Dec 23, 2007 | 08:50 AM
Ultramagdan's Avatar
Ultramagdan
Hey Dave!
Yes, post an update when you find out what the issue is.
Old Jan 3, 2008 | 10:44 AM
Super Dave's Avatar
Super Dave
my problem is with my 88 ford pick up, the truck starts fine, runs for about one hour
then it just - bup- bup - bup -runs out of gas, if you start hitting the gas, it will stall
idle,stall idle, stall idle, stall idle, rrrrrrrruuuuuummmm, then recover for ten or fifteen
then the same, untill the onetime it just dies. then it starts right back up, a couple of times untill it won't start again. then after it cools down it will start again. I have seen where others on here were having the same problem. I replaced Both the fuel pumps,
filter, relay,cat converter, ignintion switch,MAP,TPS, O2 sesor,by-passed some of the in-line fues.I've put some dry gas in it, fuel injector cleaner couple of times, yet my results are the same. I have't done the brain(yet) but could it be the chip in the brain. Nothig is lighting up on the dash for me to put it on the diagnostic mashine, I've ask the man at auto zone he told me, no lights I can't do anything.
Old Jan 3, 2008 | 11:52 AM
Super Dave's Avatar
Super Dave
first I did the plugs, wires, car, rotor- but this sounds like it could be a fuel problem.
Old Jan 3, 2008 | 03:41 PM
Super Dave's Avatar
Super Dave
I thought I had it fixed but now it is back to the same thing. Maybe someone has the solution. I'm sure this had to be a common problem back in the day. Any suggestions would be helpful. Now I'm going to try the charchol canister. what do you think?
anyone?
Old Jan 3, 2008 | 05:08 PM
Ultramagdan
Post in the 88 forum: https://www.ford-trucks.com/forums/forum28/ or the 460 forum: https://www.ford-trucks.com/forums/forum53/ You will find expert help in those forums and we get a response from those having that application.
prochef
New Member Introductions
Jan 8, 2018 11:50 AM
JoyRidingLordofDeath
Mar 11, 2015 05:44 PM
Seth1583
Jun 23, 2014 11:21 AM
jordan grant
Jan 25, 2010 06:33 AM
