Engine stalls out.
Old Dec 22, 2007 | 08:52 PM
JEOL's Avatar
JEOL
Engine stalls out.
Have 1966 F-100 300CI 6
Just rebuilt Ford carb,single barrel but runs same as the old Holley carb only worse
Starts fine and responds to the manual choke but as I increase the RPM it seems to miss and bog down. Checked timing, vacumn advance, fuel supply, all OK. If I did not know better I would say there is an ail leak in intake.
Any ideas anyone? Slowly getting every things fixed.
Old Dec 22, 2007 | 11:28 PM
rogue40's Avatar
rogue40
Sounds like a vacuum leak.
Old Dec 23, 2007 | 08:13 AM
JEOL's Avatar
JEOL
Going to try spraying something around carb and intake to see if it changes rpm.
Another thought is the size of the jet in carb. manual says 69. The one in the first holley was 62.
Old Dec 23, 2007 | 08:32 AM
Redmanbob's Avatar
Redmanbob
make a trip to harbor freight unless you already have one then, get busy...http://www.centuryperformance.com/vacuum.asp
Old Dec 23, 2007 | 04:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
300 Carb Parts List # 95.11 ~ 1964/72 Ford Truck Parts Catalog
Jet #69F / 0 to 5,000 ft altitude = C3TZ-9533-B (Motorcraft CJ-132)
Or (depending on the carb ID tag) >
Jet #68F / 0 to 5,000 ft. altitude = C3TZ-9533-F (Motorcraft CJ-149)
Jet #67F / 5,000 to 10,000 ft. altitude = C3TZ-9533-C (Motorcraft CJ-139)
Jet #65F / 10,000 to 15,000 ft. altitude = C3TZ-9533-A (Motorcraft CJ-131)
Carb Kit: C8OZ-9A586-D (Motorcraft CT-207-A)
Float: C3AZ-9550-A (Motorcraft CM-430)
Acc. Pump (also comes with kit): C3AZ-9B559-A (Motorcraft CM-432)
Old Dec 23, 2007 | 07:18 PM
flipklos's Avatar
flipklos
Does it do it once the ewngine is warm. If not just warm the engine. or rich the choke slightly.
