Sagging Ceiling
Old Dec 22, 2007 | 02:13 PM
FordF350Baby's Avatar
FordF350Baby
Sagging Ceiling
On the passenger side of my single cab 95 F350, the ceiling has randomly began to sag, and I dont know what i should do about it. I dont want to reupholster it, is there any kind of penetrating glue that i could spray on it and push it back onto the ceiling? Any suggestions be appreciated
Old Dec 29, 2007 | 09:24 PM
triton_2002's Avatar
triton_2002
Best way would be to take down the headliner and redo it, but since you say you don't want to.........I would see if I could get an edge of the fabric loose, spray some rubber cement in there and stick it back up. It should hold for a while, but will probably just continue to sag with time. Or you could always go with the thumb tack look........
Old Dec 30, 2007 | 09:55 AM
FordF350Baby
Hmm, your probably right, I should just redo it
Old Dec 30, 2007 | 01:30 PM
ChrisNJ's Avatar
ChrisNJ
I agree w/ triton. Just take it down and redo it. The glue has most likely just failed and it'll only get worse from this point on. Headliners are very easy to take down imo. Once you pull the whole thing down, see if you can remove the fabric w/o damaging it. If you can, just pick up some 3m spray adhesive and hit both sides, then reapply the fabric using a roller. I would think this would do the trick perfectly. Also consider some vibration/sound deadening material on the roof while the headliner is down. Makes a big difference in wind noise imo.
Old Dec 30, 2007 | 05:52 PM
FordF350Baby
Yeah, it is worth the extra effort. I will do that this week. The sound deadening material is a good idea, but how should i apply it without the weight of it making it sag as well?
Old Dec 30, 2007 | 07:14 PM
triton_2002
The sound deading (dynamat) material should be applied to the roof and the headliner on top of that. Dynamat is an asphalt type material with a heavy aluminum foil side and a sticky side. The only thing I would do is make sure there isn't any rust on the roof (and sand/seal any existing rust) before putting on any sound deading material, as this may lead to moisture buildup.
If you have an local fabric/upholstery shop, you can find the headliner material there. It has a thin foam applied to the fabric already and use contact cement to stick it to the headliner board.
Old Dec 30, 2007 | 08:28 PM
FordF350Baby
sweet, thanks triton
Old Dec 30, 2007 | 09:13 PM
cdrmotorsports's Avatar
cdrmotorsports
Well worth your extra time. Do it right the first time.
Old Dec 31, 2007 | 12:08 PM
ChrisNJ's Avatar
ChrisNJ
Triton beat me to it again Yes, the dynamat (just one brand), I personally used second skin audio products are a lot of research, is applied to the roof itself. I applied 2 layers of their damplifier then one layer of overkill before reinstalling the headliner. There should be plenty of room in there for you to do 2 layers of whatever brand you choose.
anyway, if you have any questions as you go through the install, just let us know
Old Dec 31, 2007 | 12:17 PM
FordF350Baby
You guys are great, thank you all for responding with helpful and succint information.
Old Jan 8, 2008 | 02:50 PM
FordF350Baby
dudes....I took the headliner down, and I knew instantly this job wasnt going to be easy. I pulled the liner back just fine, but when I added the adhesive and tried to put back its all wrinkly and nasty and really fu**cked up. Do you guys know where I can buy one, this job is horrible, damnit.
Old Jan 8, 2008 | 08:24 PM
ChrisNJ's Avatar
ChrisNJ
damn sorry to hear bro. Did you try using a roller to put it back on? I'd almost say a 2 person job. One person to hold the loose end up, and one person to slowly roll it back on.
Old Jan 8, 2008 | 08:36 PM
FordF350Baby
Yeah I tried the roller, but the new glue wouldnt follow the old contour of the liner, it came out okay, but deff not new looking. It looks just as ugly as before, minus the sag, now its just sort of ripply looking, but its okay, I will look for a new one or have someone do it for me. Thanks again guys.
Old Jan 9, 2008 | 09:16 PM
Lead Head's Avatar
Lead Head
My neighbor takes a staple gun when the frabric sags completely, and then staples differerent designs into the fabric of his various vehicles
