Ride Height Specs
Old Dec 21, 2007 | 08:57 PM
Mr Dave73's Avatar
Mr Dave73
Ride Height Specs
Anyone know where I can find ride height specs for my 75 F-100 Supercab 2wd? It has the factory size tires. It looks low in the front, but I may just be used to seeing newer trucks sitting higher in the front. Any help would be appreciated.
Old Dec 21, 2007 | 09:32 PM
masterbeavis's Avatar
masterbeavis
It is supposed to sit low in the front, they all do. New springs will not fix the "problem" either. You will have to lower the rear end to get it to sit level, or special order springs that are stiffer or taller to lift it up a little bit. Changing the ride height will change your alignment, be forewarned.
Old Dec 22, 2007 | 09:54 AM
PPG908629's Avatar
PPG908629
Check with an alignment shop. Ride height is often listed as an alignment angle. Not that everyone actually uses it for anything ("toe and go" shops abound around here......), but the specs are in the database. I pulled specs for late 60's Mustangs from Hunter software at my last job, so mid 70's p/u shouldn't be an issue for a good shop.
Franklin2
Apr 26, 2023 07:29 AM
jedijeb
Jun 1, 2015 07:59 AM
1964FORDTUF
Jun 15, 2014 11:43 AM
davz
18
May 13, 2013 08:06 AM
Ken Blythen
Aug 8, 2012 01:25 PM
