Sponsored by: Real Truck
2008 leveling kit. Do I need it?
Old Dec 21, 2007 | 09:51 AM
Bug1964's Avatar
Bug1964
Ok guys, maybe someone can help me out here. I have a brand new 08 superduty that I want to out 35 inch tires on. One of the custom shops told me 35's will fit with no level lift as long as the stock wheels are replaced with after market wheels with a 4.5 inch back spacing. Has anybody done this? It would save me a little cash and eliminate the front leveling kit I was going to buy first. As for the level kit, any suggestions? I have been looking at Readylift and Tuff Country. Would like to go with Donahoe but a little to expensive. Any comments would be greatly appreciated.
Old Dec 21, 2007 | 10:10 AM
powerstroke1350's Avatar
powerstroke1350
you can fit 35's on it right now. dont need wheels or anything. you were talkin to an idiot.
Old Dec 21, 2007 | 11:04 AM
Bug1964's Avatar
Bug1964
Thanks Ryan. I had one guy at Ford tell me 33's and another guy at a different Ford dealer tell me 35's no problem. Heck, I had 33's on my 150 with no mods. Thanks for your help.
Sherrie
Old Dec 21, 2007 | 11:10 AM
powerstroke1350
no problem! enjoy your 35's!
Old Dec 21, 2007 | 06:22 PM
NFC002's Avatar
NFC002
I have an 06 SD and had to use a level kit because if it bounces or turn sharp it'll rub.I don't think the 08 is any higher.I'f you do use a level kit,it will move the wheel over a bit because it changes the track bar.Also went with air bags in rear cause when you load up the rear will drop.I would of rather gone with a lift because it would address these little problems and i'f I want to go larger no worries
Old Dec 22, 2007 | 05:50 PM
z71burb's Avatar
z71burb
35/12.50-20s - no lift - no problems on stock wheels
wheels turned full crank - about 1" worth of space between tire and radius arm
Old Dec 22, 2007 | 07:09 PM
Bug1964's Avatar
Bug1964
Thanks! I appreciate the Pictures. Nice truck1 Have a wonderful holiday!
Old Dec 22, 2007 | 07:10 PM
redford's Avatar
redford
FTE Leadership Emeritus
The 35's look real good at stock height, ZZ71burb.
Old Dec 22, 2007 | 09:03 PM
z71burb's Avatar
z71burb
thanks - i ended up lifting it up just a little, just for kicks. 2.5" in the front, and a set of 350 blocks in the rear.
Old Dec 23, 2007 | 07:21 AM
skirk55's Avatar
skirk55
I put a Ready Lift kit on my 2005 F350 and 35" tires. The 35" tires are a little small you can put 37" tires on this truck with no problem. I like the leveling kit it is perfect!
