Knocking Sound
Old Dec 20, 2007 | 05:40 PM
padrejerry's Avatar
padrejerry
Knocking Sound
Hi everyone. I have a 1997 Ford Ranger, 4 cylinder, 2WD.
I have been noticing a knocking sound when I'm driving at slow speeds. While I don't know for sure the sound appears to be coming from the back of the truck somewhere. At normal to high speed I don't hear anything.
It's not from a recent gas fillup because it's been doing this for a while now with several different fillups. What does it sound like it could be?
Old Dec 21, 2007 | 12:46 AM
reddog99's Avatar
reddog99
Coming from the back, the most likely thing would be U-joints...
Old Dec 22, 2007 | 01:34 PM
padrejerry's Avatar
padrejerry
Thanks for the response reddog. I thought I read somewhere that worn u-joints usually cause a screeching sound of some kind? I might be mistaken.
Old Dec 22, 2007 | 11:58 PM
reddog99's Avatar
reddog99
They can make a variety of sounds, depending on exactly how/how much they're worn. Just crawl under there and grab each end of the driveshaft in turn. Give it a good shake/push/pull. Any detectable difference in movement between one part of the U-joint and the other part means it's bad.
Old Dec 23, 2007 | 03:02 PM
pawpaw's Avatar
pawpaw
If you could be a little more descriptive of the "knock" sound, maybe we could narrow it down some more.
Is it more of a metallic, clank, clink, tink, ping, or more of a dead/dull sounding, clunk thump, bump????
The latter could be suspension, like shocks or rubber bushings, or exhaust hangers.
The former may be driveline, like U joints often make a ping, or excessive differential backlash might make a clink sound, or loose lug nuts mght make more of a rattling sound.
You could put the rear end up on stands & have someone run the engine & driveline, while you do a walk around, "look & listen".
Just some more thoughts for pondering.
Old Dec 23, 2007 | 03:34 PM
padrejerry's Avatar
padrejerry
Sure, I'd have to say it's more of a dull clunk or thump type of sound. When I start to speed up though I can't hear it anymore, that could be because the sound of the engine blocks it out, don't know for sure. When I hear it though it definitely sounds like it's coming from the back somewhere.
I'll take the suggestions here and see if I could get a better idea of what it is.
