Block Heater Question
Old Dec 20, 2007 | 02:51 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
I HAVE A 96 F-450 PSD AND WAS WANTING TO KNOW FIRST IS IT OK TO PLUG IT IN ALL WINTER BECAUSE IT SITS ALL WINTER LONG WITHOUT DRIVING IT. SECOND DOES IT WARM THE OIL OR WATER.THIRD IT USULLY STARTS EASY BUT IT IS GETTING COLDER HERE IN OHIO AND IT HASENT BEEN STARTED IN ABOUT A WEEK AND IT DIDNT WANT TO START TODAY IT CRANKED OVER FAST BUT DIDNT WANT TO GO. BY PLUGGING IT IN WILL THIS HELP START EASIER. LIKE I SAID IT SITS ALL WINTER LONG WITHOUT DRIVING IT SO I WOULD LIKE TO START IT EVERY NOW AND THEN JUST TO KEEP THE BATTERIES AND STUFF UP.
Old Dec 20, 2007 | 03:24 PM
FFemt5287's Avatar
FFemt5287
plugging the truck in will generally make starting easier, yes.
as for the truck sitting all winter, i wouldnt advise intermittantly starting it and jsut letting it run. if you are going to drive it for a fair amount of miles, yes, thats fine. if you are just going to start it once a week or whatever and run to go get milk, that is not necessarily a good thing for the engine. it will not get up to temperature and will introduce moisture into the engine. if you are going to let it sit and not drive it, i would pull the batteries and put them inside somewhere warm on a trickle charger for the winter. treat the fuel with a good diesel fuel treatment to help fend off any algae, gelling, or water build up in the fuel. in the spring, put the batteries back in and fire her over. good luck.
Brandon
Old Dec 20, 2007 | 03:45 PM
Neal 97 250's Avatar
Neal 97 250
Brandon said it best, I agree. And if you do drive it every now and then just plug it up about 3-4 hours before you start it and it should be fine.
Old Dec 20, 2007 | 05:16 PM
FARM69's Avatar
FARM69
Yep, it will be fine sitting there all winter. Just make sure your batts are good.
Old Dec 20, 2007 | 05:23 PM
PAVEMENTMAN
I Dont Know Why It Had A Hard Time Starting Today For, Must Have Been Cause The Oil Was So Thick Ah.??????
Old Dec 20, 2007 | 05:37 PM
FARM69's Avatar
FARM69
Hpop oil level may have been low from sitting. Sometimes it takes a little once they have been sitting that long. I wouldn't worry about it much.
Old Dec 20, 2007 | 05:48 PM
PAVEMENTMAN
Will The Oil Pan Or Block Be Warm To The Touch If The Block Heater Is Working.
Old Dec 20, 2007 | 05:51 PM
FARM69's Avatar
FARM69
I'm not sure. They may be... pry the lower hose would be. I would just check the resitance of the block heater.
Zoltan 97 7.3
38
Dec 19, 2013 08:09 AM
RedLang
Sep 13, 2011 08:47 AM
Troutfly1
May 12, 2011 05:47 PM
Greywolf
24
Jan 11, 2008 08:38 PM
88763739
Sep 10, 2007 10:37 AM
