Sponsored by: Auxito
Shift pattern for 98 4.6 2wd A/T
Old Dec 20, 2007 | 12:32 PM
Phillip Guidry's Avatar
Phillip Guidry
While upshifting...does the t-conv. lock up between 2-3 or 3-4 ?...also...when the OD is off via the button on stick......does the t-conv. lock up at all ?....and...what occurs during braking and deceleration to the t-conv. ?...I get this funny driveline/brake vibration that you feel thru the seat when braking and speedo gets to the 40 mph mark.......doesn't do it above or below this range ?
Old Dec 20, 2007 | 01:26 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
If you get a vibration while braking, I would suspect a warped rotor.
And yes, the torque converter does lock up.
