e4od starts in 4rth gear
Old 05-20-2015, 07:37 PM
ponticelli1221's Avatar
ponticelli1221
ponticelli1221 is offline
Reverse 1 and 2 work fine put in D hit the gas and get high rpms and truck barley moves like it's in fourth gear tranny fluid level color is fine no smell?????
Old 05-20-2015, 08:44 PM
dixie460's Avatar
dixie460
dixie460 is offline
Check the computer for fault codes. Might be a bad range sensor but it could also be a slipping clutch although I don't have my E4OD clutch chart handy so I can't see if your symptoms point to any specific clutch failure. But depending how much you revved it trying to get it to move you might have just killed it anyway.
It wasn't in 4th, it was just slipping.
Old 05-20-2015, 08:50 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is online now
Received 1,576 Likes on 1,054 Posts
If there is no power to the shift solenoids it will do exactly what you are describing. There are two red wires from pins 37 and 57 on the EEC connector that supply power to the solenoids. I'll bet these wires do not have +12 volts.
Old 05-22-2015, 09:02 PM
ponticelli1221
Orielys said there's no power to the eec test to check the cel services it today same thing going on switched eec relays didn't changed anything so maybe the pcm or what was stated no power to the Dec which might make sense since there's no power to check the cel?
Old 05-22-2015, 09:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
whats the specs on your truck? what is it?
9th gen under hood fuse box;
notice not just the relay but the fuses I and U.
as stated by Mark,you've got no power getting to your trans control unit.this is the reason for high gear starts.
if the truck is a 9th gen (92-97) then the od cancel light will be on all the time in this situation as well.though half it's normal brightness when od is canceled.
Old 05-22-2015, 09:18 PM
ponticelli1221
It's a 93 f250 7.5 od light isn't on
Old 05-22-2015, 09:19 PM
ponticelli1221
I wasn't sure which was the pcm relay I can check that too now
Old 05-22-2015, 09:33 PM
FORDF250HDXLT
could just be the 92-94 idi diesel e40d's teca thing.
most often this is the fault.you can try trading the horn relay in and she will probably start right off in 1st again.
Old 05-22-2015, 09:52 PM
ponticelli1221
I hope so that would be great although the horn doesn't work so I hope the relay is good y'all are very helpful thank you I'll try tomorrow and let y'all know
Old 05-23-2015, 09:34 AM
ponticelli1221
Checked fuses and swapped relays still nothing
Old 05-23-2015, 01:55 PM
Mark Kovalsky
You might want to try this. Or you might want to go buy parts and install them. Your choice.
And you took a non-working horn relay and swapped it with a non-working computer relay. What did you expect to happen?
Old 05-23-2015, 02:18 PM
FORDF250HDXLT
relay's are cheap lol.you can plug in a generic from the auto stores.just snap off the universal mount so the lid on the power dist box can still close.
Old 08-26-2015, 06:01 PM
ponticelli1221
Well transmission started working again on its own
Old 08-26-2015, 10:27 PM
FORDF250HDXLT
might want to get under there and inspect your solenoid pack connector.
Old 06-02-2020, 08:43 PM
Garrison Ijames's Avatar
Garrison Ijames
Garrison Ijames is offline
Did you ever figure out what was wrong ?
Quick Reply: e4od starts in 4rth gear
